Should I?
  • OpaDC
    • Feb 2008
    • 393
    • Pensacola, FL
    Should I?
    http://pensacola.craigslist.org/tls/735191797.html
    Any thoughts on this?
    I don't know this brand. Then again, I don't know many.
    _____________
    Opa
    second star to the right and straight on til morning
  • Stan
    • 966
    • Kalispell, MT, USA.
    • BT3100, Delta 36-717
    Even though it is not very wide as far as planers go, I would jump all over that for the molder capability. Foley Belsaw is mainly into sharpening equipment now, but there older woodworking equipment is of good quality.
    I would check on molding knives from the seller also.
    http://www.elksigndesigns.com
      It's a quality machine, and parts are probably still available. But, it doesn't have a very large capacity. For $75 it's pretty cheap if you get some use out of it. If you like the idea of a combination machine Foley-Belsaw makes a planer/moulder, that is similar to Woodmaster. Either of those can produce a multitude of mouldings, do straight planing, or drum sanding.
