Wixey planer read-out upgrade
  • charliex
    • 632
    • Spring Valley, MN, USA.
    • Sears equivelent BT3100-1
    Wixey has an upgrade read-out available for their planer scale. It's $20.00 for the unit. I just installed mine yesterday and it is much easier to read due to the angle and has a brighter display. It's easy to install and has a larger battery.
    If you upgrade you can purchase another scale for $10.00. Then you can build a blade / bit set scale or a DP depth scale using the old read-out.
    Any other suggestions as to what could be done with the old one will be appreciated.
    http://www.wixey.com/planer/spareparts/index.html
    Chas
  • jhart
    • 1715
    What planer model are you using with the Wixley? Was it fairly easy to install?
