Lathe Purchasing Advice
  • bthorne
    • Oct 2007
    • 82
    • Ruckersville, VA
    I've been thinking about getting a lathe recently, and saw this ad come up on Craigslist. http://richmond.craigslist.org/tls/712592781.html
    The seller responded to my email questions with the following:
    The lathe I believe is 110 v, (plug is 3 which fits in any outlet) and the lathe is a UL (r) Bench Pro 4 speed wood lathe written on front. It is 5 feet long and 12" tall, the wooden bench my father made to work from is table length high (3 ft) and 4 ft long. I do not have the ability to load photos yet on the site. Sorry
    Any thoughts on what brand/model this might be, and whether it's worth driving 1.5 hours out there to check it out? It sounds like the seller's father was in charge of the industrial arts program for many years in Richmond, and might have had some quality tools. Seller says it's in great condition.
    Also - if I do go take a look, what things should I be looking out for, especially if it's an older lathe?
    Thanks for your advice,
    Bryan
    Bryan
  • Russianwolf
    • 3152
    • Martinsburg, WV, USA.
    • One of them there Toy saws
    you should ask him what the bed construction is. Pressed Steel, Steel tube, or cast iron/steel.
    The pressed steel beds tend to flex a lot, the tubes can be hard to maintain alignment. The Cast beds are the easiest.
    Otherwise a pic is worth a thousand words, maybe more. Even a camaera phone and texting the pic would give you more info.
    Lakota's Dad
      Seems the ad has been deleted, so this may be a moot point.
      • Russianwolf
        • 3152
        works for me
        Lakota's Dad
          I meant in this case, Mike. Your points are still valid, but the OP may have to use them to consider a different lathe...
          • Russianwolf
            • 3152
            no, I mean when I click the link the lathe is still there. I don't see the usual "this post has been deleted'.
            Lakota's Dad
              I get a deleted message. You might be looking at a cached page.
              • Russianwolf
                • 3152
                DOH!!!
                Nevermind.
                Lakota's Dad
