SawCam
  • scmhogg
    • 1839
    • Simi Valley, CA, USA.
    SawCam
    This morning, I got the "Wood Staff" email. They included a report from the National Hardware Show. There were a number of new and prototype tools featured in the Wood report. Including hydrogen powered tools that need no electricity.
    I was facinated by the SawCam miter saw from GMC.
    This is the Wood writer's description:
    "GMC also launched a new sliding mitersaw (10 and 12 inch models) with a built-in TV screen. The Sawcam mitersaw features a small viewing screen above the handle and switch that allows the user to see the cutline at varying levels of magnification. This should help users to make more accurate cuts and keep their hands clear of the blade. (The camera is mounted just below the pivot bolt.) These dual-bevel mitersaws feature motors mounted at a 45° angle next to the arbor shaft, powered by bevel gears that produce the same rpms you get from a standard shaft-driven mitersaw and do away with the belt-driven, top-mounted motors. These saws will be out this fall and should sell for between $350 and $400."
    Steve
    Combining actual TV screens w/ tools is getting seriously close to tool porn.
    I like it, though. As someone with a bad back, I think it would help me line-up my cuts w/o straining my back to do so.
    • final_t
      • 1626
      I knew I should have taken the patent out on the concept two years ago when I dumped the elcheapo webcam on a long usb cord into the dust collector bin to see what it looked like.
      • Tom Slick
        • 2913
        • Paso Robles, Calif, USA.
        • sears BT3 clone
        I was looking at that saw from the same email this morning. the only thing I potentially don't like about it is that it takes your eyes away from the business area of the saw and puts them up and away. That might not be an issue though.
          Tom,
          I don't think I'd buy it for that very reason - it distracts you from the cutting operation.
          • 91FE
            • 303
            • Philadelphia (actually Souderton), PA.
            My thoughts exactly... you'll get a nice action shot of what it looks like to chop off your fingers.
            I like Wagoneers too. Hey...they've got wood
            • Duff
              • 164
              • San Antonio, TX
              • Enco 12" RT
              Not bad-mouthing the miter/compound miter saw, but I use mine for ROUGHing the size of the workpiece, not extreme accuracy. IF the cut is within 1/4" of what my final size it, I'm good. No need for the gadgetry. . .
              Enco 12" RT table saw(with router table currently added to right wing), Central Machinary 6" jointer, Delta 16" (17-900) drill press, Ridgid 14" bandsaw, Jet bench top Mortising machine, Porter Cable 6901 series routers (2) and a wide variety of Ryobi 18v tools.
              • pacwind3
                • 257
                • Vancouver, WA
                • Bosch 4100
                It would be better if you could show the New Yankee Workshop on the screen so Nahm could show you how he would have done the cut better then you
                  I reckon that camera won't work very well with blood spattered all over it...
