Air File--A new tool
  • scmhogg
    • 1839
    • Simi Valley, CA, USA.
    Yesterday, a friend bought me an Air File at HF.
    http://www.harborfreight.com/cpi/cta...temnumber=1704
    I have always hated having to sand the inside of cutouts or inside curves. This little gadget with 3700 strokes per minute, takes away material in short order.
    I have wrapped sand paper around the flat file and it seems to work great. I am going to make some different shaped wood paddles with rod stock epoxied in the ends. I will then glue sandpaper to the wood.
    Not bad for $16.
    Steve
  • Hellrazor
    • 2091
    • Abyss, PA
    • Ridgid R4512
    Nice idea. I wonder what 40grit would do on something that fast...
    • BobSch
      • 4385
      I don't know. But keep you fire extinguisher handy...
      Bob
        That could be one of the gems in their inventory.
        • Stytooner
          Roll Tide RIP Lee
          • 4301
          • Robertsdale, AL, USA.
          I do like the idea of this tool. I find though that filing is a finesse type job for the most part. I use a grinder and a 1" belt sander most often. These don't always get where I need and then I do break out the files. I can see where grabbing this might be a good idea. I'll have to keep my eye out for that. Thanks.
          • dlminehart
            • 1829
            • San Jose, CA, USA.
            Now, if I only had a compressor that would handle 8 cfm!
            - David
            • billfrommich
              • 74
              Does anyone know how this tool would perform at a reduced air supply -either correct pressure at reduced CFM (if that' physically possible) , or correct CFM at reduced pressure (more likely)? Are the stokes per minute reduced or the stroke force reduced or both? I don't see either as being that bad a tradeoff as I see this tool being used with finesse more than brute force.
              • scmhogg
                • 1839
                Bill--My HF compressor is only rated at 4.9 cfm at 90psi, and the file seems to work great. I have not tried at a lower psi yet.
                Steve
