Surface jointing with router
  • jussi
    • 2162
    Anyone know of any plans/pics of a router sled for surface jointing/planing.
  • iceman61
    • Oct 2007
    • 699
    • West TN
    • Bosch 4100-09
    As I recall there is a good one in the book "Router Magic" but I can't look it up at the moment. My book had been "borrowed" by a friend.
      Here is one where they flatten a bench with it (the woodwhisperor, also talked about one of those):
      http://www.highlandwoodworking.com/l...ingitplane.pdf
      Our own Lee Styron has a simple one on his website....
      http://www.leestyron.com/sled.php
      That doesn't even include fancier homemade ones, like the ones I have seen that use metal dowel rods, in the edge guide holes. Those run between the runners.
        Here are a few. they all use the same basic principal.
        1. you need to set the rough stock on a known level surface e.g. benchtop, stable plywood or MDF.
        2. Setup 2 rails that are exactly the same height on either side of the stock.
        3. create a sled to which the router is mounted that will slide over the rails and allow the bit to reach the full area of the stock to be planed.
        4. Shim the stock to ensure it does not rock.
        5. Use a bottom cutting bit that is wide as possible.
        6. Sweep the router back and forth along the rails lowering the bit for each pass until the surface is "smooth."
        When complete the surface will have assumed the same plane as the rails.
        I have one that I used before I got a planer. I still do use it for very rough stock to get the major lumps off first.
        You should note that although the result may look "smooth" there are probably faint grooves and differneces in thickness as its very difficult to get the bit to stay at the exact same depth as you push the sled. Therefore you will need some careful sanding. Wipe it over with some mineral spirits and you should more easily see any imperfections.
        Best to catch them now as they will show once you stain/finish the piece.
        http://www.popularmechanics.com/home...p/1274411.html
        http://www.jeffgreefwoodworking.com/...ch/index3.html
        http://www.taunton.com/finewoodworki...F.aspx?id=2198
        • jussi
          • 2162
          What type of bit is used?
            Niki had a very good thread here.
