Why did I wait so long to buy Cool Blocks
  • smorris
    • Apr 2003
    • 695
    • Tampa, Florida, USA.
    I've looked at them and read about them but never seemed to actually buy some. I finally needed to get some new blocks for the bandsaw and saw them on the shelf so picked up a set. All I can say is WOW. After using those cheap plastic blocks these are night and day and I was tripping over a dollar to pick up a dime by passing these by.
  • MilDoc
    I agree. Short of making your own, cool blocks fit the bill!
    • Lonnie in Orlando
      • 649
      • Orlando, FL, USA.
      Paul:
      I make blocks out of oak, but they are nothing special in the performance department. How do you make yours?
      - Lonnie
        • 8793
        I have them on an old Sears bandsaw and like them much better than the metal guides there were there before. Cool Blocks are great!
        • MilDoc
          Originally posted by Lonnie in Orlando
          Paul:
          - Lonnie
          Sorry if you misunderstood. I use cool blocks too.
          I have read that using hardwoods with natural oils work well but have never tried it.
            Seeing as we're on Cool Blocks and making your own blocks, I've been thinking about replacing my Cool Blocks w/ steel blocks. The Cool Blocks wear unevenly and need to be dressed. And I don't use my bandsaw that much, really. So I'm a little surprised how quickly they round-over.
            I've also thought of brass as perhaps a happy medium. I did a little research and found some other people using brass, but I have no idea if it would wear faster/slower than Cool Blocks (suspect slower). And if I'm concerned about wear, then maybe having the steel and just keeping a constant (albeit somewhat wider) gap makes sense.
            I wish I could try rollers but I have a small Inca bandsaw and the guide holder won't accomodate them.
            • Lonnie in Orlando
              • 649
              • Orlando, FL, USA.
              Thanks, Paul -
              I was hoping that you had the secrete key to perfect shop-make blocks.
              - Lonnie
              • Sid
                • Apr 2004
                • 139
                • Bloomington, IL, USA.
                • Craftsman 22124
                I've been quite satisfied with the ceramic guide blocks I've been using. They don't wear away like cool blocks do, and seem to be very low friction.
                Sid
                • ironhat
                  • 2553
                  I would think that the brass blocks would wear pretty quickly as well. I haven't done this but you could check www.use-enco.com and see if they have any bar stock of the correct dimension in bronze which would be a bit harder without being damaging to the blade set. JAT.
                  Blessings,
                  Chiz
