Pretty neat tool for setting router bits
    Originally posted by mclear6
    Other than ordering from a woodworking supply company, where else can you find high density plastic to help create router set up blocks?
    Other than a WW supply MC, I don't know. I keep it on hand and purchase it from Peachtree Woodworking about 15 minutes away from me. I just buy a 4" x 36 or x 48 sheet and when I need it, it's there. I made a lot of jiggy's and things.. so it's easier than purchase just when I need a piece.
      UMHW can also be had on Ebay, but shipping puts in line cost-wise with a local Woodcraft purchase.
        I only use one setup gauge and it is for my HF dovetail jig. I made it from a scrap of 3/4 plywood. With the BT3100 I cut a deep notch in the center about twice as deep as the depth setting I wanted. In the center of the notch, I put a fine thread drywall screw. With the bit set at the height I wanted, I adjusted the screw until it just touched the bit. Now that little jig is in the drawer of the base for the dovetail jig.
        I have pieces of wood scraps about 2 inches by 4 inches that I originally made to adjust my Skil biscuit jointer. They vary in thickness from 1/8 inch to about 1 1/4 inches by 1/16 inch/block. I use these same blocks to adjust the depth of the BT3100 and routers. I just put one of the desired depth against the blade or bit and adjust to match. Usually that is close enough for what I am doing. I find it harder to make a mistake doing this with a block of wood with the thickness clearly written on it than if I measured.
