Dowels in plywood
  • milanuk
    • 287
    • Wenatchee, WA, USA.
    Dowels in plywood
    Hello all,
    Well, time for another silly question: dowels in plywood. Specifically, using a DowelMax jig.
    I've started on some projects - building various shop carts, cabinets, etc. Figured I'd try some different techniques on some of them just for educational purposes - better to screw up... ah, that is, 'learn' on shop projects than big projects for someone else right?
    Got a Kreg pocket hole jig; using it for a planer cart w/ drawers that I'm working on. Pretty slick, learned a few things so far. Next project will probably be done using the PC557 biscuit joiner thats been sitting neglected on the shelf. After that... dadoes, nail gun, etc. I want to form some of my own opinions, and work through the execution of the various processes for myself. With help, of course!
    Which brings me back to the original topic: dowels. I've got one of the cheesy little $20-30 dowel jigs from the local hardware store (General brand, I believe) that someone got me for a stocking stuffer a Christmas or two back. Honestly not too impressed with it the little bit I puttered around with it, and I'd always heard this-n-that about how dowel joints were fussy to line up, etc. Didn't sound like my cup of tea.
    Now that the DowelMax jig has been on the scene for a while, it seems like nearly anyone who uses it praises it as the second coming - expensive, but nearly idiot proof (I like that!) and very easy to get good consistent results. Okay, sounds good so far. I've seen examples of many different kinds of woodworking using dowels, but I don't think I've seen any that weren't using solid stock.
    Are dowel joints totally unsuitable in plywood cabinet or carcass construction? Why or why not?
    TIA,
    Monte
    All right, breaks over. Back on your heads!
    Dowels work just fine in plywood applications provided the alignment is right and the right size dowel is used. There are some very inexpensive jigs that set up the alignment, and you can use "dowel centers" which are cheap.
    Foremost on any joinery, fastening or alignment method, is to evaluate the application and decide which method will be best.
    • milanuk
      • 287
      Thanks for the response!
      I guess what I was getting at was that in my (past) experience, the edge holding ability of plywood has been less than spectacular for things like screws, etc. - even more so than end grain in solid stock. As such, and given that a dowel takes a considerable bite out of the thickness of a piece of plywood, I just wondered if I might be really stretching things.
      Monte
      • MikeMcCoy
        • Nov 2004
        • 790
        • Moncks Corner, SC, USA.
        • Delta Contractor Saw
        The Dowelmax ought to work fine. I've used an inexpensive drill guide and Miller Dowels and never had a problem holding.
        • big tim
          • 546
          • Scarborough, Toronto,Canada
          • SawStop PCS
          I agree with the other posters about using dowels. This cabinet was built using the Dowelmax, not a single screw other then of course for the hinges, just dowels and glue.
          after finishing:
