MCLS Horizontal router table?
  • Wandere
    • Dec 2007
    • 100
    • Madison, WI area
    I'm looking to mount a new Freud FT2200E into a table and start getting it dusty. (first router...may be overkill)
    Any thoughts on the MCLS horizontal? Lower price direct than from Amazon:
    http://www.mlcswoodworking.com/shops...ter_table.html
    The only thing you really couldn't use it for would be the giant cabinet face bits I think. Price is still a bit high but and it looks easy to get to the router, etc.
    Thanks,
    -Rob
  • JohnnyLisa
    • Oct 2005
    • 33
    • Pensacola, Florida
    • Sears Craftsman # 21829
    DIY horizontal router table
    Don't know if you'd be interested in building your own, but Bill Hylton's book Router Magic has plans for building a horizontal router jig that can be added onto an existing cabinet or table.
    John
    • Wandere
      • Dec 2007
      • 100
      • Madison, WI area
      I sure would, will try to find it....sounds like the best of both worlds then, little compromising.
      Still in the tool acquisition phase, haven't made a lick of sawdust towards any "building something new" goals. A home built router table might just do the trick.
      -Rob
      • 180x
        • Dec 2006
        • 163
        • North Augusta, SC
        A router table cabinet was my first venture into woodworking. It whet my appetite and I learned a few things. I built it using pocket screws.
        Dwayne
        • Wandere
          • Dec 2007
          • 100
          • Madison, WI area
          Very cool 180, a Kreg jig is on my wish list too. Mentioned it to a woodworker at work and got a raised eyebrow...lol
          Found some plans, want to grab a big Al plate soon...found a nifty one on the 'bay
          • 180x
            • Dec 2006
            • 163
            • North Augusta, SC
            I saw a video for making wall panels by Norm on New Yankee Workshop where he was using them for assembly (I did the wainscotting in my living room using it). Also, Marc Sommerfeld has incorporated it into his cabinet making system. It's a true time saver IMHO.
            Dwayne
            • mpauly
              • 337
              • NJ
              A kind soul here emailed me plans for a shop built horizontal router table. I haven't built it yet, but it looks simple and effective. If you like, PM me your email address and I'll forward it on to you.
              Michael
              • Wandere
                • Dec 2007
                • 100
                • Madison, WI area
                PM coming your way, thanks.
                • Crash2510
                  • 830
                  • North Central Ohio
                  have the same router in my table. great powerful router. I think you can use vertical raised panel bits to still do that kind of routing
                  Phil In Ohio
                  The basement woodworker
                    My router table can do either vertical or horizontal. To add the horizontal capability I took a chunk out of the top in the middle at the back and then made a magnetic mount so I can put it back when I am using the vertical feature. The mount for the router is just a piece of melamine covered particle board that pivots on one lag bolt that is in the 3/4 plywood back of my router table and is in a slotted hole on the other side so you can adjust the height. I glued shims made from old business cards to the edges of the melamine router mount to get it square to the top of the table. Kind of crude but works fine. I think I've used it 3 times or less in the 5 years or so I've had it. For the few added bucks I have in my setup I think it was good to do but as a whole additional tool, I don't think it would be worthwhile for most woodworkers.
