Ramsets are available at home depot or at the lumber yard.
Paslode nailers are not any louder then any other nailers
15ga vs. 18ga, or both? it depends on what do you plan to use the nailer for? for just regular interior trim you can easily hang it with a 18ga no problem. some guys in the trade are moving to 23ga pins for basic interior trim, especially if it's stain grade.
Hammer drill vibrates as it drills so that you can drill into concrete and block.
Impact driver works the same way that a tire store's impact gun works for installing your lug nuts except the impact driver is for screws. they are lighter and more compact then a drill and once you use one you will not know how you lived without it. it will drive a deck screw all the way though a 4x4 and out the other side if you want it to.
I do some remodeling work on the side and I use my impact driver far more then my regular drill, especially when framing. it is also much quicker to have both a drill ready with a drill bit and the impact driver with a screwdriver bit instead of constantly switching between bits.
Glad I don't have to go to that much trouble.
