I finally got the Wixey Fence Indicator installed on my 22811. It turned out to be a lot easier than I had anticipated.
I chose to forego using the supplied hardware and mounted the Wixey rail directly to the fence rail with 4 sheetmetal screws.
I made a bracket for the magnetic catch from a small "L" bracket smacked flat. I rounded it off on the grinder. I attached it the fence by tapping it with a 6-32 hole.
It only took about 20 minutes to do all this. This is the best new toy I've had in a long time. I zero'd it against the blade, moved the fence 2.00" and did a short rip. Checked it with a dial caliper and it was 'dead nuts' on.
This product is well worth the money ($100 including a Wixey digital angle gauge).
