Grizzly G0478 Owners...Zero Clearance Insert ?
  • burrellski
    • 218
    • Saint Joseph, MO.
    I know there are a few owners of the Grizzly hybrid around here now. My question is...
    Has anyone purchased the Zero Clearance Insert from Grizzly? I was planning on just making my own, but the little metal clip on the back of the stock insert has me wondering if its possible.
    Anyone who owns a Grizzly zero clearance insert, can you take a picture of the bottom side or just describe the layout? Is there are retainer clip like the stock insert?
    Thanks
    Matt
  • goslin23
    • Feb 2007
    • 233
    • Richmond, TX
    • Rigid TS3650
    On my TS3650 the insert has that tab on the back that you mention (I think that's what you mean). I simply put a small screw near the bottom of the insert and clipped off the head, works fine.
    Sorry for the fuzzy pic, crappy camera.
    -=gos=-
    If it ain't one thing... It's 12 @#$%ing things!
    • burrellski
      • 218
      • Saint Joseph, MO.
      The grizzly has a metal spring clip that is spot welded to the top surface of the stock insert. It slips under the back surface that supports the insert. I'll try and get a picture, its hard to explain.
      • Knottscott
        • 3815
        • Rochester, NY.
        • 2008 Shop Fox W1677
        Can you substitute a small wooden tab for the clip?
        Grizzly's website shows these pics...looks a bit like the old Emerson made inserts from Craftsman. Griz shows 13-15/16" x 3-11/16"
        • burrellski
          • 218
          • Saint Joseph, MO.
          You're right, I probably could substitute a snug fitting wooden tab for the metal clip. Just curious what the actual Grizzly version was like. I could also drill and tap the back ledge where the clip would typically go.
