Surface rust
  • Luckbox
    • 371
    • Holly Springs, NC
    Surface rust
    What is the best way to remove surface rust?
    Is it bets to use steel wool, the synthetic stuff, or just sand paper?
    If you use sand paper should it be done by hand or would a power sander work better?
    My table saw, band saw, and jointer has some rust on them from my move and being stored for 8 months so I want to get them back into shape. I have some of the top saver solution and plan on finishing the tops with some Johnson’s paste wax, unless there is a better solution.
    I love lamp.
    Do not use steel wool... It will leave steel particles imbedded in the surface which will themselves rust. A "fake" wool pad, some WD-40 and lots of elbow grease will remove the rust, but then you should clean the WD-40 off with acetone or denatured alcohol, so it won't stain your work. After that, you can use paste wax, Empire Table-Saver, or Boeshield T-9 to seal the table. I prefer to use the Empire, because it is made specifically for this purpose, and does not leave wax on the surface (this may or may not be a problem for you). Also, be prepared to repeat the process periodically, especially if the tool is in use.
    • Dale In Corona
      • Jan 2005
      • 81
      • Corona, CA, USA.
      I like to use the T9 product "Rust Free" to remove the rust. I find that after I apply it and let it sit for a minute or two that most surface rust just wipes off with a soft cloth or paper shop towel. I have occasionally taken a green scrubby pad to some areas of heavier rust before removing the Rust Free with a soft cloth (wear gloves, a respirator or at least a mask and eye protection if you start scrubbing away).
      After I have thoroughly wiped off the Rust Free and let the material in question dry I apply a coat (or two) of T9 Boeshield. Whether I let it dry completely or wipe it off between coats depends entirely on the item being protected and the likelihood for it to rust again.
      You can pick both items up at sears in a kit for about $20 and you will get many applications out of it.
      Here is a link: Sears T9 Kit
      Dale
      PS It should be noted that I have no affiliation with ANY of the products or compnies mentioned and that the oppinions expressed are solely my own. I take no responsibility either expressed or implied for anything. YMMV.
      Last edited by Dale In Corona; 11-09-2007, 10:56 AM. Reason: Standard disclaimer #304
        I just derusted my jointer. I used the plastic scrubby pads and some WD-40. Wiped off the excess then wiped the whole thing down with mineral spirits. Once that evaporated I went back over it with Johnson's paste wax.
        • Holbren
          • Oct 2004
          • 707
          • Orange City, FL.
          Boeshield works good for my tops.
          I was in the garage the other day only to find that everything is rusted. Every handle and nut on my combo machine. table saw blade plates, bandsaw blades, allen wrenches, handplanes ... What a mess.
          What do you do Cracker? You live in the most humid place on earth too.
          Brian
          www.holbren.com
            I re-coat a lot. And I make a habit not to touch anything I don't need to work with. Can't do much else... I do have a de-humidifier in my shop, and the sawdust on the floor seems to help...
            • Holbren
              • Oct 2004
              • 707
              • Orange City, FL.
              A de-humifiier helps I'm sure. My family comes and goes through the garage door so that's not really a good option and I catch **** for the sawdust. Hmm, time to insulate the garage door, add A/C and tell them to use the darn front door that's probalby rusted shut from not being used.
              Brian
              www.holbren.com
                Yeah, the wife told me either the sawdust goes, or she does... I'm gonna miss her...
                • Crash2510
                  • 830
                  • North Central Ohio
                  I use a rust remover that I use on guns before Instant gun blue
                  Phil In Ohio
                  The basement woodworker
                  • dlminehart
                    • 1829
                    • San Jose, CA, USA.
                    That's one thing I'll miss about my BT3: no rusting tops!
                    - David
                    • eezlock
                      • 997
                      • Charlotte,N.C.
                      rust removal?
                      I use scotchbrite pads on the ros and wd-40, then clean that off and apply a couple of coats of minwax and buff it out, really does a good job for me!
                      eezlock
                      • p8ntblr
                        • 921
                        • So Cal
                        • Craftsman 22114
                        T9 works well but will discolor the material. WD-40 takes alot more elbow grease but doesn't stain. I've also heard good things about a product called TC11 but have never used it.
                        -Paul
                          Dupont rubbing and polishing compounds work. Neither of them contain silicones.
                          I use very fine (maroon) and ultra fine (grey) 5" Scotch Brite pads on my ROS to clean and polish. If you go this route, buy an extra H&L pad just for this purpose.
                          • Tarhead
                            • Aug 2007
                            • 34
                            • Concord, NC
                            • Delta Unisaw
                            You may want to consider Mother's aluminum wheel/metal polish and a big can of elbow grease if WD40 and a Scotchbrite pad don't give you satisfaction. I used this to rehab and old saw top and it worked well.
                            I've had excellent results keeping rust away with a mineral spirits/Gulfwax mixture. I grate 1/2 of a bar of Gulfwax pariffin (found in the canning section of your grocery store) and disolve this in ~6-8oz of mineral spirits. I store this mix in a spray bottle and spray my cast iron surfaces once/month. when the mineral spirits evaporate I buff with an old towel. I figure that the expensive snake oils are basically the same stuff. I only pay about $0.55 for 8ozs.
                            Note: Keep this in a heated space. It turns solid when it gets to ~45 degrees.
                            Mark
                            • Luckbox
                              • 371
                              • Holly Springs, NC
                              Thanks for all the ideas guys. I found that scotchbrite pads on the ros with the top cleaner starting with course all the way up to fine, and then finishing with Minwax pastwax left the top very clean and smooth. It tok two coats of the pastwax before the cloth was comming up faily clean. I might put another coat of wax on jut to make sure.
                              I love lamp.
