grip-tite magnetic feather board
  • jemmy
    • Sep 2007
    • 42
    • IRELAND
    • Hitachi C10RA
    hi there, can anyone tell me about grip-tite magnetic feather board. has anyone got/used them yet? i would love to hear from you as i`m a paraplegic and have only the use of one hand. and have just hear about them. thank you, Jemmy.
  • mschrank
    • Oct 2004
    • 1130
    • Hood River, OR, USA.
    Are you using a BT300x TS? If so, note that a magnetic hold down won't work on the aluminum table.
    • gwyneth
      • 1134
      • Bayfield Co., WI
      jemmy has a hitachi.
      There's a thread about the Grip-tite, which made me sort of pine for a ferrous table:
      http://www.bt3central.com/showthread.php?t=29337
      Grip-tite
      • sdk1000000
        • 10
        I use the Grip-Tite Pro kit with my BT3100. The Pro kit has the friction rollers that push the stock towards the fence. I bought the steel fence plate accessory and made a 3' plywood fence, with a recess for the steel plate, that I attach with nuts and stove bolts to the stock fence. Just use a nut size that fits in the extrusion in the fence. The set-up with any type of push stick gives me great control when cutting long stock or plywood sheets and I never place my hands near the blade.
        When cutting small pieces I use the Gripper. While these accessories may seem expensive a single trip to the ER costs much more and they usually can't reattach your fingers anyway.
        • jemmy
          • Sep 2007
          • 42
          • IRELAND
          • Hitachi C10RA
          Grip-tite
          hi there, you are rite Gwyneth, i have a hitachi C10RA do you think it will work with my saw ? and if not wat do i need??? thanks for your time Gwyneth. Jemmy.
          • Jeffrey Schronce
            • 3822
            • York, PA, USA.
            • 22124
            I have a "pro" set that rarely makes it off my BS. They are great for resawing tall boards. I use them a feather boards on the TS against the edge of the wood, I have never used them on the fence as a hold down.
