Different way to make the "Square Checker"
  • niki
    • 566
    • Poland
    • EB PK255
    Good day
    When I posted Steve's "Square checker" on another forum, somebody suggested to make it with wheels...so, I did...
    I used 6 mm (1/4") dowels because the Hole Saw is drilling 6 mm at the wheel centre.
    The dowels are getting into the holes so tight that I even use dowel instead of bolt to sand the wheels as you will see on the pics.
    Regards
    niki
  • Crash2510
    • 830
    • North Central Ohio
    very nice and simple design. I'll add it to my list of things to do.
    thanks for sharing
    Phil In Ohio
    The basement woodworker
    • tkarlmann
      • 360
      • Hoffman Estates, IL, USA.
      Rollers?
      The implimentation I saw of this tool had sharp points on the ends of the sticks. What do the rollers add?
      Thom
      Thom
      • PlainSpeak
        Been lurking for a long time...
        Great pictures and notes - you seem to have professional 'writer' background.
        • niki
          • 566
          • Poland
          • EB PK255
          Than you so much
          Thom
          The wheels are adding - precision...
          With the sharp points version, the sharp point edge, should have a "virtual" zero dimension width and I noticed that what works on the drawing board with lines (that also has some width), does not work in the actual case.
          The wheels are touching also only on one point but, at the same point for all different angles between the long arm and the short arm points.
          Another "by-product" of the wheels version is that, the short arm wheel will not touch the corner and the glue squeeze-out at the corner.
          PlainSpeak
          English is not even my first language...as you probably noticed...but, "once upon a time" I was instructor...
          Regards
          niki
