Jet vs. Tormek Sharpeners
    I am presently struggling with this decision, as I have an opportunity to purchase a Tormek in excellent shape with a couple accessory jigs for 2 Benjamins. I can get a new Jet unit for about $260. I had heard that the Jet was actually an improvement over the Tormek, but I'm not so sure after reading this side-by-side comparison. I have investigated the Work Sharp system also, but since I have a lot of planer blades wider than 2", this system did not seem as attractive. The HF system just doesn't blow my skirt up either, so I'm still choosing between the Tormek and the Jet. The only knock on the Tormek I've seen with any regularity is the high price, but that is out of the equation for me with this impending deal. I haven't seen any comments that the Tormek does not produce the superior edge. Anybody have some thoughts?
    • 8807
    Here is a link that "seems" to give a slight edge to the Jet because of its variable speed.
    http://www.newwoodworker.com/reviews...ekcomparo.html
    • Jeffrey Schronce
      • 3822
      • York, PA, USA.
      • 22124
      Not going to go wrong either way.. .
        Got it!
        Had to make a decision to avoid losing the deal. Went with the Tormek. Came with the two-sided stone and grading jig for the wheel, the auxiliary leathers and almost every optional jig except the axe rig, most of them unopened in their boxes. Doesn't look like this rig even got used more than twice. Think I got a steal.
        Edit: Yikes! Just added up the cost of the extra accessories I got, and it's almost $500 not including the machine or the standard accessories! Now I'm feelin' a little guilty... There! Not any more...
        Can't wait to shave some hairs off my arm!
        • bthere
          • 462
          • Alpharetta, GA
          I think you got an absoulute bargain. The Tormek will last forever and does a fine job. If you got alot of accessories you saved about a million bucks right there.
          • Jim Boyd
            • 1766
            • Montgomery, Texas, USA.
            • Delta Unisaw
            Get ya a big box of Band-Aids, you're going to need them Sharpening all of the kitchen knives is good for at least one cut and no hair left on your arms
              What a score!
              Unc, when you run out of arm hairs and start using other body parts we will gladly drop the 'no pics didn't happen' rule.
                What a score!
                Smart move, Ken...
