Flush Trim/Pattern Bit & Dado Clean Out Recommendations
  • Jeffrey Schronce
    • 3822
    • York, PA, USA.
    • 22124
    Title pretty much says it all. I will likely stick with Whiteside bits unless I hearing compelling reason not to do so.
    I am thinking a 1/2" shank, 2" cutter length and 1/2" diameter with a double bearing on top would be pretty good choice. Would you recommend spiral trim bit? This will be mounted in a table, so up or down spiral? Or stick with pattern bit?
    Also, don't seem to be able to find a dado cleanout bit on Holbren or Hartville. Anyone have a part number for Whiteside dado clean out?
  • RodKirby
    • 3136
    • Mao Shan TSC-10RAS
    IMHO - Router table, upcut spiral (to pull the waste down).
    If I ever have a choice I will ALWAYS go spiral - slice is better than scrape
    Downunder ... 1" = 25.4mm
    • Jeffrey Schronce
      • 3822
      • York, PA, USA.
      • 22124
      Thanks for confirming my thought. I am having problem finding a 1/2" shank spiral upcut with bearing on top and bottom. Anyone know if there is such a beast?
      Thanks
        I looked at Amana, Whiteside, and MLCS. The only double bearing trim bits I found were staight cut. FWIW, I have both the 1/2" and 1/4" spiral flush trim bits from Whiteside. The trimmed edge on plywood is better than you could get by sanding!
        • Tom Slick
          • 2913
          • Paso Robles, Calif, USA.
          • sears BT3 clone
          take a look at onsrud, they make some very good spiral bits.
            Spiral is what I use most of the time. I do a fair amount of work with curly materials, and it does a great job. I have a whiteside in the router right now for that purpose.
            It makes less of a difference for Dado though, IMO.
            • RodKirby
              • 3136
              Thanks
              Couldn't find one with top+bottom bearings but...
              http://www.woodhaven.com/detail.aspx?ID=2073
              • Jeffrey Schronce
                • 3822
                • York, PA, USA.
                • 22124
                Cool, I am glad to hear that. Guess I will end up with flush upcut spiral from Whiteside with 1/2" cutter diameter and 2" cutter length.
                Edit : BTW, I am amazed at how much less the Whiteside bits are than some of the others out there. Other than Holbren kit and Freud raised panel set I pretty much have stuck with Whiteside. I figured they were priced about the same as the other players. Amazing that the price is better and they generally are rated the highest.
                  As usual, I'm throwin' in a thought here. Depending on the type of material and its thickness, I may pattern out the layout and cut it close on the BS or jig saw first, so that there is only about an 1/8" to finally rout off to the pattern. For that a plain 'ole flush 3 flute with a bearing works pretty good in a table. Of course with a top bearing the pattern has to be on top of the stock. FWIW,
                    I asked one of my tool dealers about it today. He handles both Whiteside and Amana and said he has never seen anything like that in a spiral cut bit. Said if anyone has it, it would probably be CMT.
                    • Jeffrey Schronce
                      • 3822
                      • York, PA, USA.
                      • 22124
                      Thanks for the info. I checked all CMT sources and didnt find anything. I just went with the Whiteside with bearing on top.
