Fence stops (yes, also easy, fast and cheap)
  • niki
    • 566
    • Poland
    • EB PK255
    Good day
    I have seen many kinds of stops for the table saw sled fence and the drill press fence but...
    I could not find any T-Track here, so I had to make something different...
    The stops that I made have some "plus" on the T-Track ones - you can remove them out of the way very easy while the T-Track ones, have to be dragged all the way out unless, it's on hinge but, I don't like hinges because they always have some play.
    ...To the pics...
    Regards
    niki
  • final_t
    • 1626
    Awsume as always
    As usual, make a book!
    My two cents, because this has been on my mind:
    I know you like to use the super glue a lot, but I would suggest for the butt-end joints ("spread super glue at the center of this piece") to NOT use it there and instead use a typical wood glue. Super glue just doesn't have the kind of lateral strength you're expecting. Plus it's expensive!
    • niki
      • 566
      • Poland
      • EB PK255
      Thank you Final t
      You are correct.
      My excuse is (because I don't have reasons) that, there is no any structural stress on this "piece", it's just a guide to show the distance on the measuring tape, the stop will work also without this piece.
      Regards
      niki
