Bandsaw Gloat. . .
  • Duff
    • 164
    • San Antonio, TX
    • Enco 12" RT
    Bandsaw Gloat. . .
    Just picked me up a Ridgid 14" BARELY used for less than half price. The worst of it, is the bolts holding the motor and saw to the table, are rusted...oh gee, I wonder if that will affect the blade tracking (insert sarcastic tones). So, anyone else have this one and have recommendations? I'm moving up from my 12" Craftsman Bandsaw/Sander! Already rough tuned it in. Noticed the cool blocks are a little stubby, but thats an easy fix. Blade tracks about 1 1/2 degrees right on resawing and with a smooth speed, works mighty fine I think... Then again, this is my first GOOD bandsaw.
    Duff
    Enco 12" RT table saw(with router table currently added to right wing), Central Machinary 6" jointer, Delta 16" (17-900) drill press, Ridgid 14" bandsaw, Jet bench top Mortising machine, Porter Cable 6901 series routers (2) and a wide variety of Ryobi 18v tools.
    Good score, Duff. I don't know that BS, check http://www.ridgidforum.com/forum/index.php
    • Duff
      • 164
      • San Antonio, TX
      • Enco 12" RT
      Ken, I don't know how to thank someone and cuss at them at the same time, but now you've introduced me to yet another board to sign-up on and read near constantly. . . .
      Thanks
      • jackellis
        • 2638
        • Tahoe City, CA, USA.
        Get the riser block kit and consider a slightly larger motor at some point. Also, good blades. This weekend I'm finally going to try an Iturra on a 9" log.
        • Duff
          • 164
          • San Antonio, TX
          • Enco 12" RT
          Got some good blades so far. Used it again briefly tonight to work on my sons pinewood derby car (rough shaping into a 2009 Camaro (he called it). Little checking before pluging it in, all tensions good, angles good, cool blocks good, tracking good. . . table perpendicular to the blade.
          CUT LIKE BUTTA!!!
          • JTimmons
            • 690
            • Denver, CO.
            Duff
            I have this bandsaw, there was an article in the October 2006 #172 issue of Wood magazine showing how to tune it up. I haven't had the chance to do any of it myself, though.
            -- Johnny Carson
            • final_t
              • 1626
              Well I personally consider this bandsaw worth about half of the retail price, so I think you got a proper deal!
              That being said, things to do:
              1) Get the upgraded spring and hand crank with beefer nut from Iturra Designs. You can get the spring for a little more money from Woodcraft or other mail orders, but have not see the crank + nut elsewhere
              2) Replace the stock tires if the owner hasn't already. Shop around for these, make sure you're getting the pair for the price. Most places over-charge for a single.
              3) Replace the belt with a link belt.
              4) After much personal experimentation, I have found the ceramic guides & thrust bearing replacements are the best choice. I do make my own guides out of maple/hickory for the smaller blades
              As for the motor: if you have a good blade and are not doing a lot of resawing, the motor should be fine. I *did* upgrade my motor because I was resawing at the max 5-7/8" hight of the thing, and plan on putting the hieght extended someday.
              • DonHo
                • 1098
                • Shawnee, OK, USA.
                "Get the upgraded spring and hand crank with beefer nut from Iturra Designs. "
                I have a 12" jet(all my small shop will allow), the saw cuts good but I've had problems with the tension bolt and nut striping out. The first time (couple of years ago I could buy just the bolt and nut for under $20 but it happened again and they only sell the whole tension mechanism now and it's around $50. The bolt and nut were 10mm and I had no luck finding a square 100mm nut or 10mm bolt long enough locally. I just happened to find a post on woodnet about a guy who used a 3/8" square nut and 3/8" all thread. Bent the top of the all thread to 90 degrees and epoxied on a large dowel to make a tension "crank". I gave it a try and it works like a charm AND it only cost about $3. BTW the 14" jet used the same bolt and nut so I think it would work on most 14" bandsaws.
                DonHo
                Don
