Has anyone else used the General Pro doweling kit #840? I bought that when I was 17 and worked in a hardware store to fix something and it pretty much sat since (I need some decent brad point bits).
I have a possible upcoming need, and don't have anything to compare it to.
Thanks
(wondering what makes the Dowelmax and others that much better)
Short answer - the Dowelmax is the tool for dowel joints. nothing better, not even equal. and worth every dollar paid for it.
I own it for just 2 months now, and have used it extensively for a current project, and it has never failed me. I believe it's USP is that it is machined to an extreme level of accuracy, and is completely reversible. Meaning - the distance between the 5 holes is exactly the same, and the distance from either end to the first hole is also exactly the same. And 'exact' here means if you drill 2 holes by aligning the edge with the edge of your workpiece, and repeat that with another workpiece, you can be absolutely sure that those 2 holes line up, and the reference edges line up too, totally seamlessly.
I have used other jigs in the past (borrowed), and would not go back now.
- Aristotle
