Dust extraction from Bosch ROS
  • GaryA
    • 365
    • Tampa, FL, USA.
    I've got the 1295DVS Random Orbit Sander, and want to hook it up to my shop vac (even though the canister works fairly well - I know the vac has got to do better (??). I see that they sell this RS006 adapter (takes from the square adapter to round (what size?): http://www.amazon.com/Bosch-Adapter-...5384035&sr=8-1 But then they sell this VAC001 hose http://www.amazon.com/BOSCH-Standard...5384035&sr=8-1 (15' !!!!!)
    So, does anyone know - is the adapter size non-standard and you have to use Bosch's $33 hose?? Will this dramatically improve the dust extraction (I know it wont get it all), or should I just stick with the canister and dump it frequently? Thanks
    Gary
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    I have the VAC001 hose on my 1250devs and there it leaves almost no dust behind. it is a 19mm hose fitting which is a bit oddball.
    that hose seems flimsy, but I have abused it alot and it is still in great shape.
      I have that sander, and I have it hooked to my vac when I use it, there is a HUGE improvement in dust management by doing this. I do use the RS006 adapter, but from there you have troubles. I didn't buy the bosch hose, as I don't want to have yet another hose laying about. For a while I used the Fein step adapter, and that gets really close to the correct size, but you need to do a bit of taping for the connection to hold.
      Then I bought myself a 1617 router, and it had an adapter that fits the sander and solved the problem. As far as I know Bosch doesn't sell this adapter by itself, which seems stupid to me. If someone finds it, let us all know, as I'll buy another one.
      EDIT: This adapter looks to come with the bosch edge guide, which is also around 35$, but worth it if you have a bosch router.
      • GaryA
        • 365
        • Tampa, FL, USA.
        Keith - are you saying that from the RS006 there is an adapter (that was included with your router) that then converts it to standard shop vac hose?
        Is this the edge guide that includes the adapter you are talking about: http://www.amazon.com/Bosch-RA1054-D...5390981&sr=1-6 ?
        Also - isn't this the VAC002? http://www.amazon.com/BOSCH-hose-por...5391152&sr=1-1
        I feel the same way - dont want to have another hose laying around if I dont have to - but you guys have me convinced I need to get the sander connected though.
        Thanks
        Gary
