T-track stops
  • gwyneth
    • 1134
    • Bayfield Co., WI
    T-track stops
    Would people who have commercial stops for t-tracks please share some info? Which brand, which track you use it with, etc.
    Kreg makes two? Would someone need any other Kreg product to use them?
    Thanks for any input.
    Mine are homemade out of wood and work well. A few scraps, bolts, a knob a stop and a little time will get you all you need.
    • eezlock
      • 997
      • Charlotte,N.C.
      t-tracks stops
      Gwyneth, I don't have any of those stops you asked about...but I have some of the Kreg t-track. I found out that Kreg t-track is different width or
      a different clearance than normal t-track is...you can't use toilet flange bolts
      without modification and such. I had been trying other bolts and fasteners
      to make it work but no luck. I took it back to Klingspor woodworking shop
      and tried some of their accessories and it would not work. To get around this
      problem, I bought the red ShopFox brand t-track and it works with all the normal bolts and other stuff I wanted to use. I believe that not all t-track
      is made to the same dimensions, so if you buy a certain brand check to see what will and won't work together. eezlock
