The "head" on your "R2D2" looks a lot like my Toshiba vac. I liked the pict that you posted! Great tutorial!
Ladies and Gentleman - it's rolling (TS Tenoning jig)
Thank you so much
Cobob
You can see all the "it looks like your 'triangle square' & 'screw clamps' are also home made" in my posts.
Just click on my name and "View public profile" and then "find all threads started by niki"
SARGE
I'm also frustrated from the so called "Instruction manual"...
But, I'll tell you a secret from my "black past", I was in Aviation for 36 years and at some point, I was an instructor for 3 years, within this job, I had to write kind of instructions or explanations for the drawings that I was presenting in the classes...that was long time ago but probably something of that remained...
Chris
No book as long I can walk by myself to the garage...
Thanks again
nikiComment
They are probably the same with different brand names on them. Mine is a 2 speed fan also. The label on your pict says" 2 speed fan. Can't read the "speed" character due to the light reflection but the rest is readable.
Good day
I had it long time in my head and today I did it (after drilling 400mm walls for vents installation).
For the center part I used two 1-9/16" counter top boards (chipboard covered with Formica) and for the sides 18mm plywood covered with Formica (everything from left-overs).
As Vertical rollers I used iron rollers (just found them in the drawer) but if you are planning to roll it on the table, use the plastic ones.
If you are going to make it, may I advise that, first, cut only ONE center part (this 1-9/16" chipboard).
I cut it to 1/8" wider than required and then, trimmed it, 1/32" at a time, till I got the Horizontal rollers almost fit without turning the "Bolts".
Then, without changing the rip fence position cut the second 1-9/16" board to get 100% fit with the first one.
The travel, is limited by your fence length (maybe I'll make longer fence).
It's rolling nicely without any side play and the test results (on the pics) were excellent...now I have to find some project...
And the rest is on the pictures
Regards
niki
Hi niki, I don't see the pics...Comment
Hi Kmk
I re-loaded the pics...in the mean time I improved the jig by covering all the front surface with sanding paper and making a dedicated hold down clamps that you can see in other post (Hold down clamps for everything).
Actually, just two days ago I used the jig to make some tenons and it's really pleasure (and fast)...I cut the shoulders on the "Rolling TS sled" and all the process was a "piece of cake"...
Regards
nikiComment
