Must see this WOOD bandsaw.
    Originally posted by scorrpio
    What wood to make the blade then?
    Gnarly Ironwood SAWDust of course!
      I have a 14 inch Gil-built bandsaw and used to have a Gil-built table saw. I used the table saw with a homemade rip fence prior to getting a BT3100. The kits are inexpensive and work but the resulting tools are not exactly high end. I am debating retiring the bandsaw but will probably try a better blade first. The issue with it is the whole saw wobbles some when the blade is tensioned and cutting. I think it is the flexibility in the wood frame but it could be at least partially the cheap blade that it is on it right now. I put a 2x10 on the upright portion of the frame to stiffen it which helped but it is still not steel or cast iron.
      For something to mess with or for non-critical needs, one of these kits is OK. If you can afford even the HF bandsaw I am pretty sure it is better (but you will probably have to mess with the HF some too to make it work well).
        Originally posted by mikel
        I had a wooden tablesaw kit from them in the 80's
        ...mikel
        Have any pictures? Only wooden table saw I ever saw, was on usenet and made out of 2x's.
        I saw someone make one of these kits (bandsaw) and weld up a basic steel frame (scrap metal) and since I may have access to free scrap, I have thought about it. When you try a new blade, post an update.
        Thanks
        • bthere
          • 462
          • Alpharetta, GA
          We do need to see pictures of that wooden TS if you have them. Preferrably taken with a wooden camera
          • mikel
            • Jul 2006
            • 202
            • philadelphia
            • bt 3100
            Wooden cameras are easy...
            ...m
