Aluminum cutting band saw blade - tpi?
  • calec
    • Mar 2007
    • 36
    • Elkhart, IN
    • Craftsman 10" belt drive Model 113.298762
    What kind of band saw blade with how many tpi should be used to cut
    1/4" aluminum At 2780 fpm? (Craftsman 10" 21400 band saw)
  • Stytooner
    Roll Tide RIP Lee
    • 4301
    • Robertsdale, AL, USA.
    This is the blade I use on the same saw for cutting aluminum, brass, plastic and even some wood. Slices through a 2 x 8 quick enough.
    It's part number 4179A866 at McMaster Carr. I think it's $23.52 but it is a Sterrett blade. Last a good long time.
    • Tom Slick
      • 2913
      • Paso Robles, Calif, USA.
      • sears BT3 clone
      you should use an 8-10 tpi bi-metal with a variable tooth or hook tooth. if you can use a 1/2" wide blade you'd be better off.
      • calec
        • Mar 2007
        • 36
        • Elkhart, IN
        70.5 inch band saw blades
        Thanks gents! McMaster Carr, of the BIG catalogs seems the only one with 70.5 blades. Neither MSC (here in Elkhart), nor Grainger show that size. Tool Center has a nice selection & I'm sure there are other good places like it.
        • BT3 WOODOG
          • 50
          Try Sunbelt Industrial Supply! Good prices & great service. I bought 3 blades from them,custom lenghts too! Later
          • calec
            • Mar 2007
            • 36
            • Elkhart, IN
            Thanks, I bought one!
            I'm impressed with the smooth cut! (It wasn't available in 1/2")
