I was given a used TS and it seems to work fine except for rust on the table. I was planning on using steel wool 000 on the heavy spots and then a scotch brite pad. But I was at sears yesterday and they had a product called Boeshield Rust Free. It was packaged with the T9. Anyone use this product and would recommend (or not) it? Or should I stick with the steel wool/scotch brite method?
Rust on TS - Boeshield Rust Free??
Got it, like it. Wood Mag rated the T9 best at rust prevention.Happiness is sort of like wetting your pants....everyone can see it, but only you can feel the warmth.
With it, I would use the green scratch pads!!!!
I tried it, with some steel wool and an old heavily rusted square, from a friends estate. The steel wool and it, don't feel good in any cuts, and are fine enough to cut.She couldn't tell the difference between the escape pod, and the bathroom. We had to go back for her.........................Twice.Comment
Haven't used the Rust Free product, but sometimes use T9. The T9 does seem to be pretty effective as a protectant.
The last time I cleaned up a rusted table, I used WD-40 and a Scotch Brite type pad. I attached the pad to a 1/4 sheet finish sander and went at it. It's much easier than by hand and not as aggressive as an ROS. Just be sure to keep it moving and check for flatness frequently.Comment
