HF 14" Bandsaw Tires Observation
    A while back I bought new orange urethane tires for my HF bandsaw. I saw they were 1" wide which matched the width I had quickly measured the wheels on my BS to be.
    A week or so ago I started noticing that my BS was vibrating a lot more than it had. After checking alignments, etc., I checked the tires and found that the tires were above the top of the wheels on the back side.
    I removed one of the tires and then noticed that on both wheels at the back, the bottom of the 'track' for the tire has a slope up to the side of the track. The front wall of the track is at 90 degrees to the bottom. I measured the width of the flat of the bottom of the track at 7/8". This meant that 1/8" of the urethane tire width was riding on the slope, and eventually it had ridden up the slope.
    I started checking for narrower tires and all I could find with 7/8" width were Carters. As a matter of fact, the only width they offer for 14" BS's is the 7/8" width. I found them a lot cheaper at Woodline and ordered them.
    I installed them yesterday and the vibration is gone. I was concerned that at times the tires would move slightly front to back on the wheel and wasn't comfortable with that.
    I called Carter and asked about that and was told that that 'sometimes happens' and it is nothing to be worried about. They suggested that the 1/8" gap that results from having a 7/8" tire on a 1" wheel be set to the back side away from the slope.
    I ran the BS a lot yesterday evening and the side-to-side movement seems to have stopped, and the tires are resting against the 90 degree side of the wheel as they should.
    The saw sure runs better, as usual I should have bought the more expensive Carter tires at the start and not tried to save a few bucks.
    Anyone want some 1" wide urethane tires?
  • eddy merckx
    • 359
    • Western WA
    • Shop Fox Cabinet
    No thanks Ken, but thanks for doing the dirty work for those of us with HF bandsaws. BTW do you think the urathane tires run better than the stock ones?
    Eddy
