Porter Cable deal Good or Bad?
  • footprintsinconc
    • 1759
    • Roseville (Sacramento), CA
    evening everyone!
    just wanted to ask, someone is offering a porter cable biscuit cutter in almost brand new condition. he says that he used it a couple times only. the box, manual and the three different sizes of biscuits are all there. he is selling it for $125. do you think that its a good deal?
    thanks
    omar
  • mcgrath4u
    • Jun 2004
    • 205
    • Livonia, Michigan, USA.
    • Sears (Orion Made) 22124
    Thats a pretty good deal. It is going for anywhere between $190-210 around these parts and online. I haggled my way to $125 at lowes when amazon had a sale on them.
    Go for it!
      Excellent price for a great joiner.
      • footprintsinconc
        • 1759
        Thanks!
        i checked amazon, dont have it for $125, so cant go to lowes
        but good news, the other person didnt go to pick it up, so i just picked it up and just got back but i am 125 down. the box was all dusty, and there is saw dust inside looked more or less new and it is the 557 model.
        thanks for the advice!
        omar
          Check the Type number on the nameplate, omar. If it's Type 3 or 4, you're good to go. Type 2 needs a shim for the fence, but it's not a big deal.
          You're going to enjoy the 557.
            The PC biscuit jointer usually gets rated second only to the huge dollar Lamillo whenever they rate biscuit jointers. I don't think you'll second guess this one.
            • gad5264
              • 1407
              • Columbus, Ohio, USA
              • BT3000/BT3100NIB
              Ken or anyone,
              Can you tell me which nameplate you are referring to for checking the Type number? I want to check mine.
              TIA,
              Grant
              "GO Buckeyes"
              • footprintsinconc
                • 1759
                ken,
                what do you mean type 1 thru 4? what is the difference between them all?
                regards,
                omar
                • footprintsinconc
                  • 1759
                  mine is a type 1, so that means i've got to make some modifications to it? where can i get that information from? in the mean time, i will try to google it.
                  TIA: look at the side of the cutter for a black tag with porter cable 557 on it and it gives you the Type X. it also has the serial no. on that tag aswell.
                  regards,
                  omar
                    On the nameplate where the model/serial number is, there will be Type 1, Type 2, Type 3 or Type 4. It should also be on the box.
                    I believe there should not be any Type 1's around. DeWalt sued PC on the fence design. The Type 2 (that PC designed to get around the suit) had an issue with the fence alignment and required a shim. I 'think' this only affected the joiner when doing FF biscuits, but I may be wrong on that.
                    Type 3 is fixed and I have never seen a Type 4, but apparently there are some according to what I've read.
                    Here is a link with some more info if you can sift it out of the HTML code on the page.
                    Note that some users say they don't have a problem with the Type 2's.
                    I 'think' any bought in the recent past should be Type 3's
                    http://www.huntfamily.com/pc557.cfm
                    • footprintsinconc
                      • 1759
                      thanks ken for the site, that is the only site that google search results in that is of any use
                      from what i read, the real old type 1 should be ok, if the problem is there, then that means that they switched the front to mitigate the lawsuit, so it then should be just like the type 2 and the fix is the same.
                      now all i have to do is check to see if mine has the same problem. but seriously, the problem really stinks for pc reputation.
                      i am still happy that i finally go a good deal none the less.
                      regards,
                      omar
                      • Alex Franke
                        • Feb 2007
                        • 2641
                        • Chapel Hill, NC
                        ...and it is the 557 model.
                        Another two thumbs up on the 557 from me. It's an excellent machine -- even does face frame (size FF) biscuits if you change the blade (which is easy to do). Sounds like a great deal!
                        • bthere
                          • 462
                          • Alpharetta, GA
                          Congrats on the 557 purchase. This is one of those dedicated tool that makes a specific job dirt simple.
                          One of the things I've found useful is a jig for holding stock while cutting the biscuits. Mine is based on this one by Gord Graff. It works with 3/4" stock, is quick and simple to build, and easily hangs or stores out of the way when not in use.
                          • footprintsinconc
                            • 1759
                            thanks, right now, i dont even know what FF (face framing) is, got lots of learning to do......
                            in light of another tread, the box is tooooo big for the tool
                            omar
                            • footprintsinconc
                              • 1759
                              nice jig, but ......
                              that is really a neat jig! will make it for sure. thanks for the link!
                              omar
