T-Nuts
  • Headnut
    • 11
    • Villa Rica, Ga.
    • Rockwell & BT3100
    T-Nuts
    Here's a couple of pics. of some t-nuts I made.
    Doing What I Like
  • WoodButcher26
    • 167
    • Dayton, OH
    Okay, so share your methods? Tricks? Tips? Is it worth the time taken to build? Fess up!
    Kim
    Measure it with a micrometer...
    Mark it with a crayon...
    Cut it with a chain saw!
    Wood Butcher
    • Headnut
      • 11
      • Villa Rica, Ga.
      • Rockwell & BT3100
      The bolts on the right side are 1/4" toilet bolts with the heads ground down a small amount to fit the slots.
      The other ones are just square pieces cut to fit the slots drilled and countersunk with flat head 1/4" bolts brazed in place and smoothed up a little.
      It didn't take long at all
      Doing What I Like
        So aren't those Tbolts?
        That is a problem with naming, I've seen things called Tnuts, oval nuts, and extrusion nuts.
        • footprintsinconc
          • 1759
          • Roseville (Sacramento), CA
          Thanks for the how, now when are you making the knobs? are they going to be wood or plastic? post pictures
          omar
