stile and rail
  • rcp612
    • 358
    • Mount Vernon, OH, USA.
    • Bosch 4100-09
    stile and rail
    Does anyone know of a stile and rail set that is made for plywood panels? All my searches find standard sets for $75.00 (+-), then the plywood panel accessory set for $30.00(+-). It seems to me that somewhere there would be one set available for one price, but I haven't been able to find it. It's not that I'm cheap, (ok yes it is) I'm just not interested in buying things I don't need.
  • tbarn
    • Jun 2004
    • 163
    • PA, USA.
    Check out www.holbren.com
    If it is out there he probably has it.
    Great bits and he posts on this site and passes on good deals to bt3central members.
    • onedash
      • Mar 2005
      • 1013
      • Craftsman 22124
      I cant imagine making any parts ouf of plywood unless you are making flat panels in which case a rabbit bit would be the most you need if you wanted the panel thicker than the groove (just saw Norm do that)
      on my flat panels I make it the thickness of the groove. But stiles and rails or raised panels seem like they would be hard to paint even.
      • rh111
        • 49
        • KS, USA.
        There are several out there that might be a little less expensive than the ones that you found. Check with Holbren first as he is a great contributor to this forum and from time to time offers closeout out deals to this forum. You could also check woodline.com or mlcswoodworking.com. The one thing that I will note is that most of the plywood rail and stile bits are for use with 1/4" plywood inserts. Also, you need to watch the thickness of the groove being made for the ply insert. I think that the woodline plywood rail and stile groove is 5.5mm. Most 1/4" ply is 5.2mm that is found through the homecenters and most baltic birch is 6mm. I know that it is only .3mm difference, but it can leave a small gap once put together.
        It's all good till it's no good any more.
        • jziegler
          • 1149
          • Salem, NJ, USA.
          If you want a 1/4" plywood flat panel, no need for a special set or anything. Yes, there is a tiny gap. No big deal. I have done my entire kitchen with a regular rail and stile set (from Rockler before I knew about Holbren and MLCS) and it looks just fine.
          • Holbren
            • Oct 2004
            • 709
            • Orange City, FL.
            The house branded sets are 1/4" tongue and the only ones I have at 7/32" are Whiteside and they are obviously more expensive.
            In the future (next 4-6 months), I'm going to include a 7/32" tongue cutter with each R&S set or panel set. Seems like a nice feature to have.
            Brian
            www.holbren.com
