Angle Grinder with Grinding Wheel
  • thrytis
    • 552
    • Concord, NC, USA.
    • Delta Unisaw
    I'm in the process of prepping my floor for epoxy, and there are some spots that i haven't been able to remove with any chemicals or scrubbing that i've tried yet. Would an angle grinder with a masonry grinding wheel (like the type you can get at the BORG) let me grind flat to the floor, or are those designed to be used at an angle to what your grinding? I know shot blasting the whole thing is probably the way to go, but i was quoted about $425 for equipment rental and media , so i'm looking at other options to clean the floor.
    Thanks!
    Eric
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    they have to be used at an angle. if you lay it completely flat to the work the grinder is hard to control (think floor buffer wandering around)
      What about renting a power float/trowel? I think they have some grinding ability.
      • messmaker
        • 1495
        • RICHMOND, KY, USA.
        • Ridgid 2424
        I don't know what the spots are but I have used a wire cup on an angle grinder. It took some time but worked.
          A grinding cup on an angle grinder may work - you should check the RPMs. Most angle grinders run at ~10RPM. I did some grinding on my concrete counters and had to get a sander/polisher. Another thing is if you do dry grinding you need a pad with a dust hood and a very good vac system - it is dusty. I chose to do a wet grind but you may not care so much since it is not in your kitchen. A wet grind will splatter the mud all over so you need to tent off the areas with plastic.
