Rigid Spindle/belt sander evaluation
  • jcrenick
    • Jul 2005
    • 58
    • Virginia.
    Thanks for the feedback
    Due to the rave reviews I had to get it.
    • Stytooner
      Roll Tide RIP Lee
      • 4301
      • Robertsdale, AL, USA.
      Okay, I don't like it.
      Actually, I do like it, but it's really not very well made. Okay, let me quantify that. It's not a production machine or at the very least should not be used with anything other than wood.
      I have bought three of these in as many years. Mine is now shot again.
      This time however, instead of buying a new one, I am rebuilding the whole thing with pillow blocks and a new motor.
      I was floored a couple days ago when I saw my current sander start failing yet again. It had been getting rough running lately anyway.
      I took one of my old dead motors apart to find that there really isn't a suitable bearing in the top. The way the motor works is the shaft and armature moves up and down through the outer stator. It's accomplished by three plastic gears in a rotating grease filled plastic gearbox on the bottom of the motor.
      Both the top and bottom bearings are steel bushings surrounded by graphite grease in fiber packing material. Works great until you get a little heat on it. At that point the lube is gone, you have a steel bushing around a steel shaft and the temperature increases even higher, which burns off the nice varnish of the stator wiring. That apparently opens up the smoke valve.
      My recommendation is to use it minimally. At least in short bursts. Always use fresh belts. Always use dust collection. These things will keep the heat down to proper levels and shouldn't allow those cheesy bearings to overheat.
      A replacement motor, $179. New machine, $199. Rebuilt with pillow block bearings and a surplus motor = loosing the oscillation, but incorporating real bearings.
      Perhaps you may have a better service guy around your parts. Mine states that the motor is shot due to customer wear and as such, isn't warrantied.
      Sorry about raving. It is an essential machine and shuts me down completely when it goes to the sander bone yard.
        Lee, what are you using your Ridgid ... er, I mean Ridgids ... to sand? Aluminum? Polycarbonate? And how long are you running it/them at a time?
        Obviously the strife you've experienced is unknown to most of us. And a little unsettling, too, because if you've been through three of these things in as many years, it pretty much rules out the possibility that you just got a lemon.
        • softop41
          • 470
          • Plainfield, IL, USA.
          I just recently bought the Ridgid sander and am amazed how much I use it! No problems and lots of good uses.
          HTH,
          Jerry
          Jerry
          • Stytooner
            Roll Tide RIP Lee
            • 4301
            Steel, aluminum, brass, polycarbonate and yes, sometimes even wood.
            I use mine mainly with the belt sander in place. I often run the belts after they have lost the 80 grit feel, down to about a 180 feel before they are worn too much to use. I buy the good belts.
            What I have found is that it's mainly the sanding grit that gets into the motor some. I don't use the DC when I am sanding metals. Don't need any stray sparks in that system.
            I rarely have it running more than just a couple minutes. I do however put a lot of pressure on it. This and heat I think are the killer. I am not certain who designed the steel on steel bearing design, but I don't think he graduated High School shop class either. That's a formula for wear unless it's in an oil filled temperature controlled crankcase. That little bit of graphite juice in there just isn't sufficient. It's not even sealed. When it does get hot enough to run out, guess where it goes. Right down on the armature to get slung between it and the stator along with any dust that may be accumulated there. It fills the grooves in the armature so that the armature becomes in contact with the stator and then that part start wearing and heating up and viola. Shortly after, I always find myself asking forgiveness for the language that just occurred.
            Rant off. I think the machine is a good one when used along the lines of it's intended usage. I just think the designer/engineer should have a wood rasp raked along the bottom of each foot at least twice is all.
            • movnup
              • Aug 2006
              • 190
              • Seattle
              I am looking at one of these tomorrow from Craig's list for $75. Do the people that have them ever miss the 8/10/12 inch discs (what I grew up with and was going to purchase e.g. the combo belt / disc) or is this a better mousetrap and gets the job done???
              • THyman
                • 315
                • Atlanta, Georgia, USA
                Originally posted by Andrew Benedetto
                Add a graphite patten pad from WWS, makes it and all belt sanders even better.
                Andrew,
                Can you elaborate on what you said here?
                War Eagle!
                • hawkeyestoob
                  • 13
                  #23
                  Originally posted by THyman
                  Andrew,
                  Here is what he is talking about.
                  http://woodworker.com/cgi-bin/FULLPR...ARTNUM=878-512
                  Craig
                  • JSCOOK
                    • Sep 2006
                    • 774
                    • Kitchener, Ontario, Canada
                    • Ryobi BT3100-1
                    #24
                    Cool ... thanks for the link ... I'm going to have to try this on a belt sander!
