After not eating lunch for two years, I finally saved enough to get a Brand New Rikon Deluxe 14" model # 10-325 band saw. This is the one that will re-saw wood up to 13"tall.
So now that I have it (my first band saw) and after reading what amounts to every book on the subject, I still have a ton of questions.
The saw came wired for 130V, 14A, and as Ihave two dedicated 20A lines in the garage (shop), I decided to leav that way in lieu of running a 240V 7A line into the shop. Any thoughts on this?
The saw is capable of two speeds, 1445 ft min or 2950 ft min and will take up tp a 3/4" blade. What speeds do I use and when do I use them. I haven't called Suffolk to order any "Timberwolf" blades yet, hopefully they'll have some suggestions.
The saw has a "stated" HP of 1.5, so I guess it will handle most of my needs.
I plan to re-saw stock ranging from 4/5 - 12/4 into thinner slices for jewelry boxes. Additionally, I gusee that I'll do some curve cutting too, along with using the saw for making some joints.
Out of the box, the saw looks pristine. I've only asembled the bade cabinet and a HTC 3000 mobile base. I still waiting for enough guys to help me lift the sucker onto the base cab,.
Once I get it up and running, I'll do a complete (as much as I'm capable of) review of the saw.
Meanwhile, I'd really appreciate any answers you can give me on speeds and blade widths and tooth amounts to use,
Thanks in advance,
Bruce
Thanks in advance,
Bruce
A friend got his a couple of weeks ago and ordered a 3/4 4TPI and a 1/2 3TPI blade for resawing. He's also runing it on a 20 amp breaker and it didn't hesitate a bit on 8 inch oak. He actually got a smoothder cut with the 1/2 blade.
