I started a simple small project this weekend. A corner L shaped shelf to go above a child's oak table. The plan was to use 3 iron shelf brackets. I'd tie the L together with a rabbit on both butting pieces. Might take 60-90 minutes for all the milling thinks I.
I've been using a 2 HP craftsman router with dial depth.
On the second of 3 passes for the rabbits (mounted in table), the second piece didn't cut any wood. This is strange. Then on further review, the depth stop wasn't holding and depth would sink a good 1/8" or more. Nothing I could try was fixing the problem.
I'm not sure if anyone else has had this problem. I've heard negative comments about this router before here but I've never had a problem with the router. This seems to me to be a worn out stop. Not sure how to fix that.
Anyone have this problem and was able to fix it?
Seems like a good excuse to get that MV12 I've been wanting for a while (there goes the surface planner savings). Is there any drawbacks to getting the MV12 with both bases compared to the plunge router?
Needless to say the shelf and some other projects due in Jan-Feb are on hiatus
