Ridgid Right Angle Impact Driver: Thinking if gettin one
  • JonBoy
    • Sep 2005
    • 129
    • Hampstead, NC, USA.
    Just wondering if this item can be used as a wrench? I have been wanting to get the normal impact driver but these are cheaper and considering getting one but feel I will not use it as a typical impact driver due to the shape and looking for other uses to justify getting it. Anyway just wondering if you can put a socket on it and use it as a wrench? How large of a bolt could I use it on?
  • parnelli
    • 585
    I don't think I can help with your question, but I saw that item tonight at home depot, and it was the price that caught my eye- but then noticed that it was 12v while all the others seemed to be 18v which is probably why it's cheaper.
    Hopefully someone else can comment on it's usability.- I don't have any impact drivers....yet.
    • jerrye
      • 88
      • Raleigh, NC, USA.
      Size of bolt is less important than what it's torqued to. I have the Ryobi 18v impact driver and have driven 1/4" lag bolts into 6/4 dry oak; used it to strip off a damaged fender and reinstall a new one on my Plymouth Grand Voyager; driven and removed 4" deck screws; and used it to disassemble and reassemble a commercial shredder I repaired for a customer. IIRC the Ridgid you are looking at has similar torque to the 887in# my Ryobi has. No, you couldn't use it to change a tire on a car, or do heavy assembly/disassembly in an industrial environment, but for the average homeowner/hobbyist/craftsman I think it'll do fine. Why the Ridgid right angle setup and not the standard setup, whether Ryobi or others?
      EDIT: I'm hearing on other forums that some of the BORG's have the Ryobi 18v drill/impact driver set on sale for around $90.00. If yours does it's a great deal!
      Jerry
      When you think you've built it idiot-proof, they build a better idiot...
      • sacherjj
        • 813
        • Indianapolis, IN, USA.
        I looked at that to get right angle capability. Since I had Ridgid 18V drill and driver, I wanted 18V right angle. With a 12V right angle, I can't share batteries or anything. I went with the Ryobi 18V right angle drill. I figured that if I was getting different batteries, I might as well have more options with the Ryobi line. Although it would be nice at times to have the impact over the drill, the Ryobi has plenty of torque.
        Joe Sacher
        • JonBoy
          • Sep 2005
          • 129
          Reason for the right angle instead of the standard is price difference. I was trying to find a deal in ebay on a standard ridgid impact driver. However I do also own the Ryobi impact driver. Along with the 4 1/2 grinder, router, and Drill that I upgraded to a 700 jackobs chuck. As for the RIDGID I have the Drill, jig saw, recip saw, and circular saw. When I first posted I was planning on selling all my Ryobi tools and going with RIDGID. As of now I will probably keep both.
