Tom, my band saw currently (and usually) wears the same 1/2" 3tpi blade as yours, Greg's, and Ken's ... except mine is the real-deal Wood Slicer, which means it doesn't suffer the stigma of lower cost.
Sounds like there really is a consensus on the 1/2" 3tpi as a "default" blade. I think I got started with the 1/4" 6tpi as a default before I really knew how I was going to use my bandsaw. But, I find I do more resawing, and "straight" cuts than I do tight curves. (I put "straight" in quotes, because, while the cut is straight, it's not necessarily parallel to an edge, so the BS gets the nod over the TS.)
With a 1/2" 3tpi on the saw, I'm less likely to do a cut that will be hard on the blade, like I was with the 6tpi.
And, Larry, to help my blade overcome its stigma, I wrap it with a ten dollar bill when not in use.
Regards,
p.s. Yes, it was the Michael Fortune article in FWW that I referred to earlier.
