Replacing tension rod on Delta BS
  • lago
    • 473
    • Lago Vista, TX.
    I have a Delta 14” BS w/riser blocks model 28-245 that was given to me about 2 yrs ago. Ever since I had it, it was difficult to crank the tension knob. The last few times I used it, it appeared to be binding. Tonight, I noticed that I could not tension past the setting for a ¼” blade and it now looks like the tension rod threads are stripped.
    What are my options? I have looked at several threads and see favorable comments regarding a replacement rod from Iturra Design. I did get the phone # and will call for a catalog next week. When replacing the tension rod, I also plan on replacing the spring.
    Other than Iturra Design, are there any other sources that anyone would recommend?
    One last question – how difficult a job is it to replace the spring and rod?
    TIA
    Ken
    It's a very straightforward process, Ken. The rod on my HF unit stripped about a year ago. I got it fixed using parts available locally.
    The rod actually works against a square nut that's captive inside that housing with the fractional inch markings on it. Just loosen up the whole thing, then lift the housing. You'll see the nut at that point. Just continue to loosen and the rod and nut will separate.
    I just got a piece of threaded rod at the h/w store and matching square nut while I was at it.
    There's nothing wrong with getting quality parts from Iturra. I didnt' go that route and it was easy. Getting new stuff from Iturra won't be any harder.
    • lago
      • 473
      • Lago Vista, TX.
      I just happened tohave a 3/8-16 threaded rod in the shop. Might try to replace it now. I still would like to replace the spring also.
      Can the rod be removed by just turning it or do you have to remove the housing from the saw?
      What did you do to replace the knob?
      I found this when I was looking for a spring. About the same price as the OEM tension knob.
      http://www.highlandwoodworking.com/i...OD&ProdID=1299
      Ken
      • Hoover
        • 1273
        • USA.
        Ken
        I have the Quik-Crank tensioner installed on my Jet 12" band saw.
        To install it, just keep undoing the tension on the rod, you should see the square nut fall out on the bottom, followed by the tension spring.
        Replace with new rod feeding it from the top down, slide on the spring, and the new square nut. Tension it back up, and ensure that the nut is seated.
        You should be back in business.
        No good deed goes unpunished
        • eddy merckx
          • 359
          • Western WA
          • Shop Fox Cabinet
          While you're at it, you might want to make an offset handle for the top end of the rod, like the quick crank tensioner. Much easier and faster than a knob. You can make one out of scrap using the handle design from the Lynn's jig on the Lee's site, The LeeWay Workshop. Look under Projects, then Jigs.
          • jackellis
            • 2638
            • Tahoe City, CA, USA.
            I also have the Quick-Crank installed on a Ridgid 14" bandsaw to replace a stripped tension rod. I wasn't comfortable messing around with threaded rod from a hardware store. The crank is a bit pricey but worth every penny because it's so much easier to use than that cheesy knob.
