Does anyone own this jointer or have experience with it? It seems like a decent jointer for the price using a 15% coupon. I don't have a huge need for a jointer but, I need one quite often. Any help would be appreciated.
Hf 30289 ??
Did you search the threads?
Using just that number turned up 15 results with numerous replys. Don't know how many pertain to the model inquestion but I would start there.
http://www.bt3central.com/search.php?searchid=162668 -
HF 30289 jointer.....
I have that jointer....just had it for a short time (about 3 weeks), but is doing a super job so far. The instructions for the stand are at best a little confusing....so I did the next best thing....used the pictures of the stand and it went together ok.
The dust collection leaves a lot to be desired....I made a dust collection chute cover with a 2 1/2" outlet hose connection to the shop vac and this gets about 85% of the chips and dust.
If you buy this jointer, after assembly, get a good welding magnet
from HF ( shaped like an arrowhead) use it while adjusting the fence to the bed it will hold the fence in place and allow you to do adjustments and tighten it up nice, square to the jointer bed.Clean the cosmoline off really well,then put on a couple of coats of paste
wax on the bed and fence and buff it out, then you are ready to work!
Some people here don't like this jointer...that is their opinion...but what the
heck...I like it and it works well for me...don't need anything else for now
it fills the bill nicely. eezlockComment
I also have this one. Have used it for about 2 years and am happy with it. As noted it was a PITA to set up until I threw away the instructions and the fence is not easy to set square. But once setup it has preformed just fine.John HunterComment
