Ok so here’s the deal, as some of you know I had my BT3K for years and on that saw I wore out the original blade and several Freud’s over the years. You know how a blade wears out as it just stops cutting well and burning the wood etc. Well when I upgraded the saw I moved the blade I was using to the new saw as the blade that came with the new saw pretty much sucked.
Then I decided to try the very expensive Forest Woodworker II blade. I must admit I really liked it. Not too much after that I bought that Ridgid blade that Brian had the deal on and put the WWII up and was using the Ridgid Carbide. So I decided yesterday to put the WWII back into service and have been using it since yesterday. Now understand this blade has had very little use and has by no means been abused at all. Just a bit ago while setting up for a cut I noticed something not right with the blade and while taking a closer look I noticed a tooth was missing! I checked all the other teeth and they were all there but man I have never lost a tooth on a blade before!
You can bet I will be emailing Forest.
Ken
Ken
