Oh, one other little gem I picked up from my call to Iturra:
After years of use, those of us with import 14" bandsaws can expect to see the tensioning rod essentially drill a hole right through the upper casting. But, not to worry. According to Iturra, you should just let the rod bore its hole, then tap the hole for a steel bolt, and run the bolt up from underneath until flush. Now, the rod will have a much harder surface to ride on.
Regards,
Regards,
