I got my 1st ROS sander and want to know which is better/more usefull. All I've ever had before is a palm sander and one of those big 1/3 sheet sanders I got from my Dad. I like being able to change out sheets easily, but they have clips that hold the paper. These new-fangled ROS have no clips and I don't know how big of a pain adhesive paper is. Does the stick build up on the sander pad? But does the H&L reall hold, is too 'soft', or does the adhesive hook material come off?
Adhesive or Hook&Loop for ROS?
Hook and loop is the only way to go for a ROS. Quick change, the ability to swap sheets to quickly and easily swap sheet. I've only had to replace a pad once in many years of almost daily use.A man without a shillelagh, is a man without an expidient.Comment
I have a DW ROS with H&L and couldn't be happier. It is great to pop off a pad and just slap another one on.Comment
H&L is the only way to go. PSA does not hold well, IMO, and wastes disks--you never use up a disk before you need to change grits. I keep a stack of nearly-new disks by my workbench in the various grits, and it's easy to swap them off and on as needed.
KimMeasure it with a micrometer...
Mark it with a crayon...
Cut it with a chain saw!
Wood ButcherComment
Yep, I did that ONCE. Was almost impossible to get the disk off. One thing that helps is to turn it on an sand something for a while. It'll heat up the glue a bit a let you get it off. I then went out and got an adhesive H&L pad for the sander. Just got a new Dewalt ROS, you guessed it, hook & loop.AndyComment
My PC332 came a PSA pad. I also have a H&L pad for it. Thinking of asking Santa for a 2nd ROS and it will be H&L. I am convert.Don, aka Pappy,
PlatoComment
I'll go with the group, H&L for me!
I've got both the Ryobi 5" and the Ridgid 5" ROS. The Ryobi is supplied with a base for PSA disk and you can use the supplied H&L conversion pad with it. The Ridgid comes with both H&L and PSA bases that mount with screws.
I started out with H&L pads on the Ryobi and one day ran out of discs. So I used one of the PSA discs that came with the tool. What a pain in the butt that was. Now I keep a good stock of H&L pads. Much easier to change pads, never any slipping, and certainly no fouling of the base that can happen when you use those PSA discs. It's also an easy task to quickly change to a lighter grit when you are progressing through a project.
CWSThink it Through Before You Do!Comment
In addition to that, the PSA is not as padded as H&L. The disk being glued to the pad is stiffer. I've had particles get stuck under them and cause a scratch effect on the work. It seems the velcro type combination for H &L is more cushioned and easier to control.
"I'M NEVER WRONG - BUT I'M NOT ALWAYS RIGHT"Comment
