Screw Extractors - Do they work?
  • Curly Qsawn
    • 73
    • Woodbridge, VA, USA.
    I'm repairing my favorite chair and one of the screws in the bun feet has gotten mangled. Since it is in a counterbore I don't have a lot of options. Just wondering if these screw extractors work like the description or are a waste of money. Specifically, I'm looking at the x-out or one similar at Sears. Thanks for any comments.
  • Bruce Cohen
    • 2698
    • Nanuet, NY, USA.
    I got a set of three when they first came out. In most cases, they work well, you just have to exert a lot of downward force for the extractor to get a good bite.
    Bruce
    Samuel Colt did"
    • eezlock
      • 997
      • Charlotte,N.C.
      screw extractors....
      To answer your question, yes they work! The key to good screw extraction
      is proper sizing of the hole in the broken screw. The best way to do this is to use left hand twist drill bits chucked in your drill and run it in reverse ( turning
      left while drilling) when the drilling is done, clean out the drilled chips as
      best as possible, insert the screw extractor turning it to the left( reverse
      direction) and work the extractor deeper into the screw and it will eventually
      back out the broken piece of the screw. hope this helps...eezlock
      ps. you can buy sets of extractors with proper sized left twist drill bits in sets,from good tool suppliers ex: WT Tool, Snap-On, Mac or they may be available at Sears etc. eezlock
        They work if you can get a hole drilled in the screw. This isn't always easy since the screw frequently torques off and leaves on odd angle on the end of the screw.
          I've got two different types. One type is the type with the drill bit and extractor insert to match. These came in a set, and I keep them together. If you drill the correct hole (the bit for the insert) straight and take your time, the insert will remove it. The other type is a set that has different sizes of extractors that have a reverse tooth arrangement on the end that grabs the screw. This works fairly well if used properly, but not as consistant as the drill bit type. On some screws, especially old slotted screws, centering a hole is the trick.
          • Stick
            • 872
            • Grand Rapids, MB, Canada.
            A lot of times even in metal, just the left hand drill will take them out. I have reversers on both my drill presses for that very purpose.
            • rockybrown
              • 97
              if any part of the screw's head is left, and if you have an impact driver you might be able to get your screw out with that.
              • Curly Qsawn
                • 73
                ok, thanks all. I think I will try the x-outs. The screw isn't broken, I just mangled the phillips head.
                • Uncle Hook
                  • 314
                  I try to grind down the screw head when this ocurrs.
                  • eezlock
                    • 997
                    • Charlotte,N.C.
                    damaged screws
                    Might want to try tapping in a square recess head driver or a torx bit into the damaged phillips and back it out with one of these. eezlock
                    • Bob Bassett
                      • 132
                      • Shalimar, Florida, USA.
                      The latest way to get out broken screws is to use a plug cutting bit around the screw. Pull it out and then patch the hole.
                      Bob Bassett from Northwest Florida
