New idea?
  • bigsteel15
    • 1079
    • Edmonton, AB
    New idea?
    I've never seen anything similar to this before. Looks pretty cool.
    http://www.general.ca/pagemach/machines/10824_929.html
    Brian
    Welcome to the school of life
  • radhak
    • 3061
    • Miramar, FL
    • Right Tilt 3HP Unisaw
    Somehow that's got a science-fiction aura... or at least james-bond-ish.
    - Aristotle
    • sweensdv
      • 2873
      • WI
      • Baileigh TS-1040P-50
      I wonder why they don't list what the SCFM's and PSI required to make it work? I'm thinking that maybe my little pancake compressor might not be quite big enough. Pretty neat idea though.
      • nadz
        • 82
        • Rocket City, AL, USA.
        seen it
        worked at a machine shop that built a unit similar to that in mechanics...used to move big(BIG) rockets from plant to plant...like from the fabrication building to the paint booth, for instance...worked really well for the end user...wouldnt be a bad idea for a shop...
        -a
        Proudly piddling in my garage shop | BT3K, Rigid 10" CMS, Rigid 12" Planer, HF Jointer
        • MilDoc
          More info - expensive. Compressor must generate 100 lbs/inch and 5 CFM. But I've never seen a lbs/inch rating. Have you?
          http://www.taunton.com/finewoodworki....aspx?id=27031
          • jackellis
            • 2638
            • Tahoe City, CA, USA.
            The Boeing factories use much larger versions of these things to move around airplanes as they're being assembled. Sci-fi, yes. Simple, too.
            • TheRic
              • Jun 2004
              • 1912
              • West Central Ohio
              Made by General?? Please don't tell me HF General!!
              It sounds a like a simple design, and easy to use. I can also see the price dropping in the years to come with such a simple design, and probably knock offs around the corner.
              You can get by with just one. Slide it under the machine, move it to where you want it, remove the pad. Repeat
              Ric
              • dlminehart
                • 1829
                • San Jose, CA, USA.
                Uh, TheRic, I don't know how simple the "slide it under" and "remove" will be if the tool is an 800 lb jointer or whatever. I'd have to borrow 3 neighbors each time!
                - David
                  Saw this on sawmillcreek a bit back. Want to see one in action:
                  http://www.hoverbench.com/
                  • bigsteel15
                    • 1079
                    • Edmonton, AB
                    That would be lbs/sq-in.
                    I'm hoping they will have a display at the local WW show coming up.
                    Brian
