Maybe everyone already knows this but I had a incident last night while cross cutting face-joined panel made of various hardwoods. I was using the Shark-Guard and was getting prepared to make several 1-1/4" wide cuts from the panel (for WOOD magazines end grain cutting board).
My first cut was to clean the end of the panel (the individual boards were not in perfect alignment). While making the cut the waste was trapped in the blade guard and the side of the guard must have pinched the cut-off against the blade and I had several small chunks of walnut, cherry, and hard maple violently bouncing around inside my Shark.
I've had this happen before on rare occasions but usually the cut off just bounces around a little. Lesson learned - if the cut off doesn't extend beyond the edge of the blade guard then this type of cut is best done w/o the blade guard in place.
