While looking through the mailer from the Wood Working Show I see that Grripper has a new model out that is only available at the shows. I will attend the Chicago Show this Saturday and will sure check it out. I have a friend that has the Model 200 and loves it, I was planning to get one but now will see if the 230 has any advantages I can't live without.
The New Grripper 230
Tags: None
Let us know what it is like! I'd be interested in picking up another at the show in Columbus.While looking through the mailer from the Wood Working Show I see that Grripper has a new model out that is only available at the shows. I will attend the Chicago Show this Saturday and will sure check it out. I have a friend that has the Model 200 and loves it, I was planning to get one but now will see if the 230 has any advantages I can't live without.
Jonathan -
The one I saw at the show has a removable hook on the back that mine doesn't have. Dunno if that's what denotes the 200 from the 230 or not....Happiness is sort of like wetting your pants....everyone can see it, but only you can feel the warmth.
I picked up the 230. It has several extras. For one it allows two grippers to be connected together and it is a chip shield. It also has an improved handle that spreads pressure. There is also the ability to use a trailing hook to assist feeding the work piece on the table saw or router table.John HunterComment
I bought the add-on that gives the handle offsetting and the trailing hook - it was a cheap upgrade ($15?) at the time. I like it a lot.I picked up the 230. It has several extras. For one it allows two grippers to be connected together and it is a chip shield. It also has an improved handle that spreads pressure. There is also the ability to use a trailing hook to assist feeding the work piece on the table saw or router table.
Micro Jigs web site is a HORRIBLE mess. I was able to finally find the connector and sheild thingy:
http://www.microjig.com/MJDeflectorConnector.htm
I'm not sold on that as it's designed to be used - it looks like it would really get in the way. Also hooking up two GR200's in tandem is, IMHO, not great - I've seen two used in a leapfrog pattern for long boards and I think that's a good usage.
Connecting them side-by-side to make a wider overall unit might be good, but unless you can apply pressure to both (both hands over the saw? NO!) with a single handle, not gonna happen.
The *only* configuration of this that I saw worth it was the sheild to the side and using the tool to hold down a round item on the router table. And even then I'd consider the GR200 the wrong tool for the job.Comment
I agree, I love the trailing hook and the better handle setup but do not think I will be using the connector or the chip shield.I bought the add-on that gives the handle offsetting and the trailing hook - it was a cheap upgrade ($15?) at the time. I like it a lot.
Micro Jigs web site is a HORRIBLE mess. I was able to finally find the connector and shield thingy:
The *only* configuration of this that I saw worth it was the shield to the side and using the tool to hold down a round item on the router table. And even then I'd consider the GR200 the wrong tool for the job.John HunterComment
I'm interested in getting one of these. I suppose this means the Shark Guard is no longer necessary? I like the edge jointing feature as I don't have a jointer yet. That makes it worth the money right there. Uh, oh... going close to a woodcraft this morning...
Howard, the Plano BT3'r.
Confucious say, "Man who get too big for britches will be exposed in the end."
I didn't attend the funeral, but I sent a nice letter saying I approved of it."
- Mark TwainComment
