I have a older KUFO 1HP DC, but low usage on it. It is not working all of the sudden. Ran great....no smoke ever, and just tried to turn it on and nothing at all. I am clueless as to electrical motors workings.
I checked the circuit breaker, it is fine (have a light plugged in on same ext. cord to be sure). FYI: When it worked, it is one of those type of motors that when turned on there is a click sound and when turned off the click sound again (also, it would sometimes hum for a second before it would click on, but has not happened too often recently). I am guessing this sound is something to do with the capacitor? When I turn the switch on..nothing, no hum..nothing. The capacitor looks okay I think. I tested the switch with a meter on the ohm setting (not sure if this is correct)...I think this is called continuity testing?.anyway when off...no reading..when switched on the needle moves to the other side. So I am assuming the switch is okay? How do I determine if the capacitor is bad? Or what do I check now? I have attached some pics as they may be of some help maybe.
Thanks for any help
Steve
Thanks for any help
Steve
