Router Surprise!! - Safety Post
  • IBBugsy
    • 160
    • Allentown, PA.
    On my second use of a router, I was cutting a dadoe across some 2 inch wide by 36 inch long pine boards. Why not do all four at once instead of one at a time???
    I set the boards up side-by-side (along the 3/4" thickness) with sacrificial boards on each side and clamped away in several places while adding a cutting guide board. Well, when routing across the boards, I reached a board that didn't have a clamp on it and off it went into my stomach. No injury (I was going very slowly) but it was a surprise!!
    Guess I learned that squeezing a board between two others (using just the sides) isn't sufficient when using a router. I pulled out the double-sided carpet tape (which I had heard about here) and used it along the bottom of all the boards and that was adequate to hold the boards in place (along with all the other clamps).
    Dave - Weekend Garage Junkie
    "I'm no physicist but I know what matters" - Popeye
  • Bulkley
    • Oct 2005
    • 86
    • British Columbia, Canada.
    Glad you weren't hurt.
    • jseklund
      • Aug 2006
      • 428
      Thanks for the warning. I'm sure I'll be dumb enough to do this at some point in my woodworking future anyway.
        Just a reminder about shortcuts. Use common sense. In any procedure when your ready to start, think to yourself:
        1. "Is this dangerous?"
        2. "Can I get hurt?"
        3. "Is there a better way?"
        4. "Am I doing anything wrong?"
        If you get YES to any of these, get ready to call 911, or, better than that don't start.
          Glad you weren't hurt. Cawls clamped down to the table across all the boards would also be sufficient to hold them all.
