I have a question for you guys and am sure that you guys will have the answer. I recently picked up a down draft table from Wilke Machinery. I bought it off Ebay using the "Best Offer" function and practically stole the thing (gloat over).
I have a question on the Manometer. It is the following Mark II 25 :
http://www.dwyer-inst.com/htdocs/pdf.../mark2_iom.pdf
On their instructions there is a high and low pressure connection. The unit has the Mark II installed with 1 pressure connection as shown below.
Is this set up correctly? The unit came with no instructions. Basically the pre-filter consists of layered furnace filter material. Then below it is the 1 micron bags as found in a over head air cleaner. The motor is mounted to the bottom with the exhaust fan blowing out toward the floor.
Welcome to the school of life
