Ryobi Radial Arm Saws Recalled for Blade Detachment Hazard
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of Product: Ryobi Radial Arm Saws
Units: About 145,000
Manufacturer: Ryobi Motor Products Corp. formerly of Anderson, S.C. ("RMP"); Ryobi Electric Tool Manufacturing, Inc. formerly of Chandler, Ariz.; and Ryobi Limited, of Hiroshima, Japan.
Hazard: Cracking of the plastic motor housing can cause the blade assembly to fall during operation, posing a risk of laceration to the operator or bystanders. The detachment may occur unexpectedly and without warning.
Incidents/Injuries: RMP has received five reports of detached blade assemblies, including four reports of lacerated fingers to the saw operators.
Description and Models: The recall involves all RA200 and RA202 radial arm saws. These are bench top models with 8 ¼-inch blades. Each unit has a data plate immediately behind the operator grip for the saw, which says "RYOBI 8 1/4" Radial Arm Saw" and either "RA200" or "RA202."
Sold at: Home and hardware stores nationwide from 1986 through 1997 for between $200 and $300, and higher in some instances.
Manufactured In: The United States and Japan
Remedy: Consumers should immediately stop using these radial arm saws and contact Ryobi customer service to arrange to return part of the saw for a payment of $75. No repair is available.
